Disables gPTP on one or more ports.
| port_list | Specifies one or more the the switch's physical ports. |
| only | Apply change only to specified port, even if port is master of a load sharing group. |
| all | Specifies all of the switch's physical ports. |
Disabled.
Use this command to configure on which ports gPTP runs. gPTP runs on no ports if it is not enabled in the switch by enable network-clock gptp.
disable network-clock gptp ports 1-3
This command was first available in ExtremeXOS 15.3.
This command is available on all platforms if the AVB feature pack license is installed on the switch.
